Electrician Electrical shower problems plumbing advice | on ElectriciansForums
Discuss Electrician Electrical shower problems plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Electrician Electrical shower problems Electrical shower problems
I have installed a new shower and when the dial is turned to economy the light on the shower comes on but no water flows through, have checked water pipes and the are not blocked, when the dial is turned to hot or cold the light on the shower goes off, the light on my old shower would flicker on then off when it was turned on
Electrical shower problems for more information
You may reply to this message here.
Electrician Electrical shower problems to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Electrician Electrical shower problems plumbing advice in the Plumbers Forums area at ElectriciansForums.net
P
Aqualisa shower drips My aqualisa shower drips when turned off. Reluctant to change the whole cartridge (mechanical Aqualisa Thermostatic...
PaulBr
P
J
Strange Fitting? What is this?, its installed between the mains and a electric shower, when the weather gets very hot the (newish) shower stops...
John.g
J
