kkkkk
- Joined
- May 22, 2010
- Messages
- 65
- Reaction score
- 18
Hi people
I have an electrical meter to install, DDS353C - A single phase electronic credit meter with LCD readout. It is 4 x module DIN rail mounted with a max load of 100amps and pulse output. At the bottom it has supply L/N & load L/N, no problem - at the top there are positive & negative connections labelled kWh - I am not sure what I connect here - I would appreciate any advice, thanks very much!!
kWh Meter MID Certified DDS353C
