A
amckay
If I was to swap a meter for a landlord eg. What type of cert would it require? Just an EIC?
Discuss electricity meter in the UK Electrical Forum area at ElectriciansForums.net
The suppliers electricity meter is the property of the suppliers and it is an offence to interfere with it (as they state on their warning labels).Why would I get in trouble?
Genuine question...
what are you suggesting turn up on your horse as Dick TurpinIf you are taking out the suppliers meter and replacing it with a private meter, then I would also make sure that your paperwork has no identifying name or address details and that you use a different work vehicle that is not traceable to you.:cowboy:
If you are removing it this is also theft (of the meter).
Cutting the seals of the meter is also classed as criminal damage.
Removing a meter that is specifically set up to record the usage of electricity would be then classed as fraud, since you are defrauding the supplier of their means of metering.
If you have removed the meter and the result is that there is no recorded use then this is theft of electricity.
This is all I can think of at the moment.
I've checked on dnos website (electricity north west) and they state the meter is nothing to do with them and its down to supplier.
I don't think the meter is actually owned by anyone. If say it was owned by British gas by customer desides to changer supplier to say eon, would British gas "sell" the meter to eon?
Personally I can't see it happening.
As for theft (abstraction of electricity) a new meter is going in straight away??
Theft of old meter -that's up to the customer as I ain't removing it!
When a meter is changed the "person" doing the work is an employee of the supplier and they are responsible for the meter readings for the old and new meters.
I would recommend you clarify what the customer wants/has and take if from there.
Do you mean that the only person permissible to change a meter should be an employee of an energy supplier?
Just to add to that the osg may well be wrong (if you have stated what it says (i m not going to my van now to get osg out!))
The cutout belongs to dno not supplier. My dno states meter is noting to do with them. A supplier cannot readily own a meter if a consumer can change supplier as changing supplier would mean the meter has a new owner and I severely doubt that would be the case as it wouldn't be cost effective to have a national database to keep track of who owns what
The question now is what law/regulation says an electrician cannot replace a meter with another meter.
I'm after a law/regulation NOT a policy
Reply to electricity meter in the UK Electrical Forum area at ElectriciansForums.net
