C
C.B.
The electricity pulses throughout the house when the shower is turned on. I have never seen this before, so any help as to what could be causing this would be much appreciated. Thanks.
Discuss electricity pulses in the UK Electrical Forum area at ElectriciansForums.net
electrickerty can be viewed as a long tube filled with marbles, push one in one end and one falls out the other end, the same is true with water as you have seen, it kind of pulses. dont worry about it.
what the bloody heck are you talking about?
Ignore ^^^, for starters. What do you mean by 'pulses'? Are you saying that things like lights dim up and down?
TT supply by any chance? Tranny might not be man enough. If not TT then ... When did this start then? Anything changed on the installation? Might be a termination problem on supplier's side. What about neighbours, do they have the same problem? Can you measure the frequency of the pulsing, is it regular? How much is the voltage drop?The electricity pulses throughout the house when the shower is turned on. I have never seen this before, so any help as to what could be causing this would be much appreciated. Thanks.
Reply to electricity pulses in the UK Electrical Forum area at ElectriciansForums.net
