A
andreasy
Hello everyone,
I have a 30Amp heater switch that controls my hot water immersive heater and I have bought a horstmann boost control (Horstmann :: Electrisaver) which is 13Amp and I need to install this together with the heater switch in order to automatically control the time my heater switch operates.
My question is:
Both the heater switch and boost have Mains (L/N) and Load (L/N). The way I'm considering to install is to connect the mains supply on the boost and from boost out to send to heater switch mains and heater switch load to immersive heater. assuming that it is a 30Amp HS, is this correct or should I install mains supply on heater switch, heater switch load to boost mains and boost load on immersive heater?
I hope I explained well.
My question is:
