W
Welshsparky
Can i swop a standard ballast and gear tray for an electronic ballast in a 600 x 600 fluorescent fitting? If so how do I go about it?!
Discuss electronic ballasts in the UK Electrical Forum area at ElectriciansForums.net
Not sure where you get your thinking from here but Electronic ballasts have the appropriate suppressors etc to stem mains transients please explain more..... been on or off the same circuit is irrelevant a surge (spike), volts drop etc effect all loads on the same supply.Welshsparky,
dont think its a good idea to swap the ballast to HF electronic if on same cct as switch start luminaires. The initial switch surge will damage the ballast
There may be some truth in it but I haven't heard and it hasn't stopped me, if this was the case it would be printed within the installation instructions as no manufacturer wants to be getting fittings sent back.Just something I was told a few years back , so its just meant that I have always replaced like for like and not mixed magnetic and electronic ballasts on the same cct when switched on at the same time ie office lighting.
However if you thinks thats BS then that will make my life a lot easier.
Reply to electronic ballasts in the UK Electrical Forum area at ElectriciansForums.net
