Electronic Principles | on ElectriciansForums
Discuss Electronic Principles in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Deleted member 91840
Hi,
I have a module on electronic principles. One of the questions is
Three resistors of 50 ohms,50 ohms & 5 ohms are connected in series across a voltage source (Battery). If the power dissipated in the 50 ohms resistor is 100w, calculate the voltage drop across each resistor and the total voltage that must be applied to the series circuit.
I wasn't sure if i was to assume because its a battery its 12v or to work out from my two known values the resistor and the Watts so I worked out my voltage from the resistor value and the watts. My working out is as followed. I am not sure if I am on the right track or the complete wrong one any help would be appreciated?
I=70.71/105= 0.67MA
V=I*R
V1= 0.67* 50= 33.5V
V1= 0.67* 50= 33.5V
V3= 0.67*5=3.35V
V1+V2+V3= 70.35 V
Current in a series circuit is the same at all points in the circuit.
You have P = V²/R so √(PR) = V
This is the voltage dropped on the 50 Ω resistor (70.71 V) so the current is relating to the 50Ω resistor.
i.e. what current will flow to drop 70.71 V over a 50 Ω resistor
i.e. I= V/R = 70.71/50 = 1.4342 A
Then do the same calculation you have done using the new current and add up as you have done to get the total voltage dropped over allt he resistors and so this is the supply voltage needed to get 100W dissipated in the 50Ω resistor.
However I am very rusty on this type of thing and so may be completely wrong. It just seems right.
Upvote 0
Hi,
I=70.71/105= 0.67MA
V=I*R
V1= 0.67* 50= 33.5V
V1= 0.67* 50= 33.5V
V3= 0.67*5=3.35V
V1+V2+V3= 70.35 V
I=70.71/105= 0.6; This is wrong. The Current at the Series resistors are same, but the voltage drops(potential difference) are different. So, 70.71 is voltage drop only at the resistor R1.
To find current(I):
I=V1/R1, 70.71/50
I=1.414A - This current is the same to all resistors.
Since we have current is easy to calculate V2 and V3, but the voltage drop at R2 is the same as R1 because they have the same resistivity capacity.
V3=1.414 * 5
V3=7.071
There are two ways to calculate total voltage by adding V1,V2,V3 or by V=IR, 1.414 * 105 = 148.47.
THE ANSWERS:
V1=70.71, V2=70.71 and V3=7.071.
Total voltage needed = 148.47
Upvote 0
Reply to Electronic Principles in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
As you have actually measured the cold resistance (R1 + Rn = 0.15) then you have the voltage drop at the expected current (60A) so you can compute...
Hi Mainline and thanks for the reply. My inverter is only fed from the mains supply over a 4 hour period at night and it does not have any tie...
Electrical Courses
