electronic transformer | on ElectriciansForums
Discuss electronic transformer in the UK Electrical Forum area at ElectriciansForums.net
T
tbs1983
Should I be able to read an outgoing voltage from a 12v electronic transformer? using my digital multimeter, I get 8.6v for a split second then it turns to zero.
Many electronic transformers will not give an output without a lamp load or will rapidly shut down. Also, the output is often 30-40kHz AC and many digital meters will not measure this correctly.
Reply to electronic transformer in the UK Electrical Forum area at ElectriciansForums.net
Interesting. Sounds unusual since it seems it was very lightly loaded. Not much you can do I suppose other than buy a replacement unit. Unless...
hI Gent's. I I can explain this spur line briefly, maybe someone can help me? Everything is Spur, no rings. Inside of the house and main fuse...
