B
Boaky
Does anyone know how I can determine how much wattage a 105va transformer can hold and how to calc it? Not done this type of thing since college and use to using 1 transformer for 1 light
Discuss ELV transformers in the UK Electrical Forum area at ElectriciansForums.net
Yes i read all the posts .... i think Sintra has misled you here although not arguing against his formula the va rating of a electronic lighting transformer if stated for the load side will be VxA the PF value given on the transformer is the effect on the supply side, the electronics will either bring PF to unity on the load side or the va value stated is compensated ..either way just treat the va value on these transformers as wattage.That's 105 volt amps though
did u not read the threads above
Reply to ELV transformers in the UK Electrical Forum area at ElectriciansForums.net
