emergancy lighting | on ElectriciansForums
Discuss emergancy lighting in the Australia area at ElectriciansForums.net
J
james king
hi all i have downloaded some cert software and i have not used this king of cert for emergancy lighting befor can some one please help me on this part
caterogries of operation on emegancy lighting systems??
type
mode
facilities
duration
thanks
I think type is to do with the battery, either self contained or remote from the fitting, mode is non maintained/maintaned etc I have no idea on facilities something to do with how it's tested i think.
You need to get a copy of the IEE "Electrician's guide to emergency Lighting" (the one with the yellow cover)
Section 4.8 (page 46) gives all of the options to answer this.
I would print it all out here, but there is rather a lot of info! You'll have to read it for yourself.
The bit on facilities is hard to get a handle on, but Gravid is right, it is to do with test facilities.
The book is a handy guide if you are working on EL. Whilst not cheap, I would class it as an essential toolbox guide for EL.
Heres a post I made earlier.
7.10 Categories of operation of emergency lighting systems
Categories of operation are specified in BS EN 50172:2004/BS 5266-8:2004, 5.6.
In this standard, emergency lighting systems are classified according to the following parameters, as given for luminaires in BS EN 60598-2-22:1999, Annex B:
a) Type:
X self-contained;
Y central supply;
b) Mode of operation:
0 non-maintained;
1 maintained;
2 combined non-maintained;
3 combined maintained;
4 compound non-maintained;
5 compound maintained;
6 satellite;
c) Facilities:
A including test device;
B including remote rest mode;
C including inhibiting mode;
D high risk task area luminaire;
d) Duration of emergency mode (in minutes) for a self-contained system:
10 to indicate 10 min duration;
60.............1 h duration;
120............2 h duration;
180............3 h duration.
Previously, emergency lighting systems were categorized by the prefix “M” for maintained and “NM” for non-maintained systems, followed by an “/” and the number of hours duration claimed for the installation, e.g. for self-contained systems:
M/1 was a maintained 1 h duration system; this is now [X][1][****][60]
NM/3 was a non-maintained 3 h duration system; this is now [X][0][****][180]
NOTE **** in the third box stands for the facilities [see item c)], details of which are added, as applicable, at the time of installation.
Reply to emergancy lighting in the Australia area at ElectriciansForums.net
I think your profile pic will scare him away 🤣🤣
Hi all, Just wanted a bit of advice in regards to a small installation of emergency lighting. I have a fairly long warehouse that needs some...
