emergency fluorescent lighting fixtures | on ElectriciansForums
Discuss emergency fluorescent lighting fixtures in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
1983
Hi all got a 4f 4tube emergency fluorescent lighting fixture which is not working checked power no probs l n e s/l in the right places changed tubes still nuthing has no starers when I kill power off and goes in to emergency mode only one tube lights up could the balasts be dead
I don't suppose this 4 tube fitting is only designed to maintain one tube in EMG mode??
Most 4 lamp fittings have one only when in EMG action, for the OP, you say all the cables are in the right place, but when you switch on the fitting in normal usage does the s/l become live? In other words is the switch working?
Yes it is
Me thinks it's more a case of me not reading the post properly!! lol!!
So yes, suspect the ballasts!!
I've changed all the tubes I thought it could be the bit that holds the tubes not making contact but they in good condition guess it's got to be the ballast
had similar recently. 6 fittings out of 30 down. new ballast ÂŁ53 + VAT. new fitting ÂŁ48 +VAT. no brainer.
So I'm guessing you bought the Ballast's Tel.:smilewinkgrin:
And all the flourescent emergencies I've come across work on 1 tube in em mode.
Also some of these fittings the old type have starters but the starters have melted in the holding bit are they replaceable
Reply to emergency fluorescent lighting fixtures in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Or a combined fitting in each row.
nicebutdim
N
The lights are on a circuit with other lights, which is a different circuit from this receptacle. Both of these circuits and others are on the...
