Emergency light question. | on ElectriciansForums
Discuss Emergency light question. in the UK Electrical Forum area at ElectriciansForums.net
sjm
Hi guys.
I've got an emergency light (twin spot) to deal with.
I've tested the battery voltage and I'm reading 13.7 volts, the batteries are 2 x 6 volt.
When I pull the fuse or turn off the power the lights don't come on, 0 volts on the outputs.
I've replace the control board so it must be the batteries, I just can't understand where the voltage is going.
Anybody got any ideas.
Thanks in advance.
Steve.
Reply to Emergency light question. in the UK Electrical Forum area at ElectriciansForums.net
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
Ah OK, that makes sense. Thank you Avo.
