Emergency light recommendations | on ElectriciansForums
Discuss Emergency light recommendations in the UK Electrical Forum area at ElectriciansForums.net
jedisparks
Hi folks,
Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units.
I have used JCC in the past, to my cost as they had a high failure rate within the 1st couple of years. I've had good experiences with Ansell products but not tried their emergency lights yet.
Many thanks
Since the advent of LED lighting the quality/reliability of all brands has dropped like a stone, from my experience:
Ansell, high failure rate with bulkheads.
Channel, as above but the twin spots I would recommend.
JCC, high failure rate with bulkheads.
Tamlite, wouldn't touch with a barge pole. High failure rate, odd sizes, odd cable entries and the worst termination points I have come across (are designed for one cable only).
If I was to suggest a brand even though they are not perfect it would be Eaton Menvier but as I say none are the quality of the pre LED types.
Thanks for your reply
As feared. Fit anything LED, say a prayer and hope it last beyond 12 months lol!
I might even look at battery and lamp changes on a few units 1st.
Reply to Emergency light recommendations in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
That's why I directed the OP towards:
