E
evansjrraves
Got a corridor lighting problem with a non maintained e/light at the end which loses power when the 2 way switch turns all the lights off, thus bringing the light into emergency mode when all other lights are switched off. There is a 2way switch at one end with a key switch next to it. The permanent feed goes into the com of the key switch, then a link goes from there to the com of the 2 way switch next to it. there is a s/line in the key switch and the 2 strappers in the 2 way. At the other end of corridor is the other 2 way switch, next to which is non maintained e/light fitting. when switch is operated it kills power to click plug which e.l fitting is plugged into. Couldn't figure out why the e/l fitting keeps losing power and if the switch wiring or click plug wiring is wrong. Any help from more experienced people would be gratefully received.
