Emergency lighting and smoke alarms in a shared house | on ElectriciansForums
Discuss Emergency lighting and smoke alarms in a shared house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
monmouthshire
Hi there, Iam new to this so please bare with me.
Iam just about to start a full rewire. The property is a 6 bed, three storey house, which the owner is turning into shared living. 6 bedrooms with a communal lounge, bathroom and kitchen. Iam not sure if I need to fit smoke detectors in each bedroom as well as the usual landing, hall kitchen? And also what to do with the emergency lighting, do I fit the usual, landing, hall and exit doors? Or are these both different because it is shared living?
if the owner is turning it into a house of multiple occupancy HMO then a full fire alarm system would be required and emergency lighting should cover all the escape route ie hallway landing stairs and exit door but get owner to check with local council
Yeah agree with jay, you would have to find out what spec the emgergency lighting has to be carried out to.
Emgergency escape areas and final exits is probably all they'll want.
As well as smoke detectors in each room you may need sounders to get the required sound level at the bedhead.
I would suggest the owner gets in touch with the local council ASAP as he / she will need a HMO licence and the property will have to meet the council requirements for it to be granted
Good advice getting intouch with local council, as this can save you a lot of head aches later.
This sound like a Grade A system, full panel and heats and sounders in every room, smokes and call points on landing areas. possible seperate individual mains smokes in each room aswell. Emergency lights will usually be all staircases/landing areas.
Get council and fire officer to confirm before you start any installation.
Please explain never come across a situation where you would install a full panel system and then individual mains smokes as well
The idea of the council is to prevent false alarms and injuries. Basically any hmo over 3 floors is usually Grade A which is control panel and sensors. The heats are requested in each room to activate main panel in fire condition. The individual mains smokes are to give the occupier only of that room early warning of smoke, as you can see the smoke will kick in first.
Thanks for the explanation sounds like somebody on a council somewhere has a belt and braces approach to fire safety I'm surprised they don't want manual call points as well to sound the main alarm rather than wait for the heat detector to kick in if a smoke goes off and there is a fire
Sorry UNG i forgot that Grade A requires MCP on each landing , front and back exits. Difference councils vary in ideas, but most are using this idea of heats and mains smokes. Personally i would like to see Smokes in every room as in hotel installations, but can see their logic.
I'm no expert but;
Approved Doc "B" contains the definition of a "large" house, which IIRC is more than 2 floors and greater than 200m2 floor area.
Correct me if I'm wrong;
Shared kitchen and bathroom means it's not "technically" multi-occupancy.
If the area per floor is less than 200m2 then it may be legal with Grade D.
As I say, I may be wrong, I'm no expert.
Laurie
To correct you
HMO Definition in simple terms
A house which is occupied by three of more unrelated persons, who do not form a single household – this definition is supported by Sections 254 – 259 of the Housing Act 2004
More info can be found here HMO Definition
Reply to Emergency lighting and smoke alarms in a shared house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This is it though…. To put one following the letter of the law, so to speak… would be a smoke in the hallway outside the bedroom door… then a heat...
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
