Emergency lighting from existing lighting | on ElectriciansForums
Discuss Emergency lighting from existing lighting in the UK Electrical Forum area at ElectriciansForums.net
Kent
Can you use an existing lighting circuit (one switch operating one light fitting using twin & earth) to replace with maintained emergency lighting fitting with microwave sensor? The idea being that the switch becomes redundant due to the sensor, but can be used for the emergency switch test plate.
Reply to Emergency lighting from existing lighting in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
