Love this forum, you never seem to get a straight answer, bit like the regs....
P4 is it...? cant remember.
Data cable that monitors state of battery via computer interface. No need for keyswitch
I asked the commissioning engineer if there was any need for a visual check when testing EMs, "Nope" he replied just trust computer.
I didnt like that answer.
No there isn't, and I'm not aware that such a requirement has been proposed for BS5266.Is there any reg on emergency lighting should be on a key switch in bs7671, I know of it coming up in bs5266.
but they do, cause ive read it somewhere the new stuff tests auomatical or is monitored in a way that it tells you when a fault.... its their selling point... maybe more to it than the selling point as this is when they highlight the good points... im nearly sure they said you can link upto 15000 points per system
The guy is talking out of his arse!! So this numpty doesn't bother to give the EM L's a duration test in his commissioning procedures, ...I wonder what he puts down on his testing commissioning sheets, Battery voltage?? Is this guy talking about a central battery supplies for the EM L's?? I hope so, taking a point to every EML in a building, will sure eat up monitoring points ...lol!! BMS systems are very, very useful tools, but they don't and can't substitute for testing procedures!!
All BMS systems do exactly that, but they do not substitute for periodic testing full stop!!
They monitor, control, they give alarms, and information, record, access data, etc... They are sophisticated bits of kit that have numerous optional extras you can add, many of which are basically useless, but look good on the screen.
I don't think i've worked on a BMS system with just 15K points, 25 to 30K is roughly the norm on any decent sized project, but can be substantially more. The bigger the system the more important it is to have a top notch operating system that works in real time, with minimum delay times for registering alarms and faults.
Sorry, just to be clear, I asked him "When there is a key switch, this is activated during a test and the engineer or maintenance man WALKS ROUND AND VISUALLY OBSERVES emergency lighting, does he still need to do this...?"
His reply was no, the device monitors it.
I guess he was taking a point to every EM, two cables orange and white.
How many straight answers do you need then, before the penny drops??
If your looking for some sort of get out clause, there isn't one. The key switch method is generally accepted as the way to isolate the EM/lighting side of things. You can use other methods as others here have stated, such as unswitched FCU and the like, but the key switch method best meets all the requirements for testing and isolation.... Yep, it's that simple!!
