N
NigelMarsh
I have been asked to get the emergency lighting working at a nursery. They had a switch put in at the entrance to the building that switches off all of the lights in the building when they lock up at the end of the day. All lighting circuits are hanging off a contactor connected to this switch, so they are cutting power to the light circuit MCBs and pretty much simulating failed circuits when using this, "master" switch.
whoever fitted this switch saw this and wired all of their emergency lighting into its own circuit to prevent it kicking in when the lights are switched off in the evening.
this obviously makes the emergency lighting pretty much useless for its main function.
they don't want to get rid of the master switch, but the want the emergency lighting to kick in when it's local lighting circuit fails. Doh!
Any ideas on how this can be achieved without losing the master switch, even if it means switching all lighting off using a different method? I'm going grey trying to come up with a simple solution.
:banghead:
:banghead:
