Emergency lighting on minor works | on ElectriciansForums
Discuss Emergency lighting on minor works in the UK Electrical Forum area at ElectriciansForums.net
Shweblet
Trainee
kidderminster
Hi guys,
Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding multiple other fittings and emergency lighting (all of the lights were selected and at the depot when I got there) they were supplied by the lighting company next door. Em lighting was existing but adding extra fittings.
Obviously a minor works cert. Would suffice for the addition of the light fittings, but no certificate of conformity has been mentioned which I'm sure they're going to need.
Can I just issue the minor works certificate for each circuit, 1x lighting, 1x emergency light fittings and be done with it or do I need to go through with getting the emergency lighting cert sorted?
I'm registered with Napit but they haven't really given me much direction with it.
Reply to Emergency lighting on minor works in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
Or a combined fitting in each row.
nicebutdim
N
