Emergency lighting regs? | on ElectriciansForums
Discuss Emergency lighting regs? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Deltron
Hi there ppl,
Does anyone know how many lights i need in underground car-parks per square meter etc. I know each exit must be lit up with a running man exit sign but not for the main large area
Cheers
Some where between 1 and 100. Get a lighting manufacture to scheme it fella, that way you have the photometric data that has to acompany the lighting certificate when its done.
Affraid i do.
The reason i say that is if you want it to comply to regulations you must be able to proove it meets all requirements of the regulation which you obviously don't to ask. Its not a bad thing, only that you can get a lighting company to do this for you free if they think you will by their fittings. Its the best way to do it, I do this on all jobs i do now and am happy then that nothing has been missed.
Yeah thanks, i know about the book and intend to get it but i needed info now ish to prepare quote before my Xmas holiday! And to get an idea of how many lights and that. The existing lighting is already poor with many fittings not working so i was thinking of putting in new circuit of maintained lights. any ideas?!
I don't suppose anyone knows a free download, i have been scouring the net with no joy!
It makes sence to me to be a maintained lighting circuit but then i don't know the setup with daytime lighting levels, client running costs etc, you will also have to look into the size and number of exit legends which form part of the install.
i was once told the lighting had to be uniform (think this means no shadows ) but that would take way too many lights , is there another installation you can compare it to.
i'm afraid i cant compare this to another, me and my colleague have taken on a big job and its a bit of a learning curve. We are ambitious! I'm not even sure how many lights im allowed for each lighting circuit for emergency lights. and how many key activation points i need etc???!? I know in this place, half the emergency lights don't work however!
It's all well and good to be ambitious, but it's rather foolish don't you think, taking on an installation that you know little to nothing about??
think it will need a central battery back up system rather than the fittings with internal back up batterys especially from a maintenance and test point of view, if you google a company called dc emergency systems they supply all items and they also do big installations so would definatley know what you need.
From what you say it needs re-designing, Yes you can have shadows but it will be down to the lux levels in dwell areas, In the main its safe movement in main areas and the exit route should be covered along its duration, stairs, ramps change of direction and final exits should be clearly marked, Maintained lighting can be taken care of with photocell or timered switching as long as a test facility is install to each circuit. Fittings should be vapourproof design as vehicles may discharge fuel, there's a lot to take into account and most people get it wrong, just take a look at your local carpark and you will know what i mean. Most of the big boy companies Dextra, Thorn, etc will normally take a day or two to do for you .
Yes and no! I believe in myself so that helps! They have lights there existing and have had quotes but we will see. All i have to do is put in enough emergency lighting so it is adequate and improves the installation so satisfactory. Put new circuits in with key switches to test and then certificate! How hard can that be?!
got to think big to get to the top :39:
Reply to Emergency lighting regs? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
