Emergency lighting switch upgrade | on ElectriciansForums
Discuss Emergency lighting switch upgrade in the Electrician Talk | All Countries area at ElectriciansForums.net
sparkysean
Hi I have a 3 gang grid-switch which has 3 emergency key switches in the same enclosure, I want to make this a two way circuit and convert the 3 gang switch to a one gang (and obviously then I will only want 1 emergency key switch). I was planning to do this using a contactor and the new switches will are to be IP56 rated. I would like any advice on alternative methods or any potential problems that may arise. So if any body out there would be kind enough to share there knowledge I would be most appreciative.
yours faithfully
Sparkysean.
Reply to Emergency lighting switch upgrade in the Electrician Talk | All Countries area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
