emergency lighting | on ElectriciansForums
Discuss emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Farmelectrics
Wirral
is there anything wrong with having running men emergency lights over exit ways switched when ive installed them over the years ive allways been under the impresion there ment to be maintained fittings ie on at all times but not come across ones that have a switch wire aswell.
Yes, emergency exit signs are normally maintained. However, its a right pain, particularly in something like a small hall used for film shows. If the property is used for any form of public entertainment then there are specific rules and regs to follow. I can't see anyway round that one.
Most come dual maintained/non maintained these days.....link out L & SW for maintained
Reply to emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
Or a combined fitting in each row.
nicebutdim
N
