Emergency lighting | on ElectriciansForums
Discuss Emergency lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
F
ftmags
Hi, just been asked to install some new EL's, and wasn't sure if I fit the self testing units whether the key switch was still required in the circuit for testing. Thanks
If they have built in self test system then there is no need for a test switch , as i understand you can fit them as stand alone units or hook them up to a network,
Reply to Emergency lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Could also be the battery you swapped were also duff. I have had very few LED units fail. Out of a few hundred maybe a handful have had to be...
Or a combined fitting in each row.
nicebutdim
N
