Emergency Lighting | on ElectriciansForums
Discuss Emergency Lighting in the Australia area at ElectriciansForums.net
T
Tin
I need some advice, I have been asked my a friend to quote a job. He needs 2 emergency lights put up at 2 exit points in a warehouse.
I was planning to run a feed from the nearest light to the exit point, would this be the correct way of doing it?
Would I have to issue a cert, even if i fitted 1 emergency light?
Any help would be great
I was planning to run a feed from the nearest light to the exit point, would this be the correct way of doing it? As long as there is a permanant live supply present at that light that would be ok as they are supposed to operate on local power failiure. Also you may want to think about installing a test key switch for these fittings so they can be routinely tested without too much disruption..
Would I have to issue a cert, even if i fitted 1 emergency light? Always best to issue some sort of certification, generic emergency lighting certs from the wholesalers will suffice.
Maybe also consider maintained fittings, depending on the usual level of lighting
Reply to Emergency Lighting in the Australia area at ElectriciansForums.net
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
