emergency lighting | on ElectriciansForums
Discuss emergency lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Kelec1
uk
im wiring a room atm with emergency lighting. they are wired into a one way switch with no k/s. Am I right in thinking you take a live to switch (l1), with your n and e to first klik. bring a switch line to first klik (which is emergency) and onto next fitting. do I need to link all emergencys in circuit. all advice taken, thanks
kelec....Yes, but to make it easier and to save typing... (The Key switch is mandatory unless you have a self testing system that is approved)
[ElectriciansForums.net] emergency lighting
Thought this would make it easier for you to visualize.
I always break feeds and neutrals via double pole switches when installing key switches for testing emergency lights myself, but maybe thats jut me
But if you do that the other lights won't work as well. Thats if you wire it the same as the daigram above.
Normally I would wire the output of the key switch to the input of the normal switch so operating the key switch kills all power to the lights, far easier to ensure they are working, although in some situations that is not practical so do it as above.
Turn the MCB off during the day or fit any kind of switch.
Doesn't have to be a key switch.
Switch should be located in an area only accessible by authorised personnel.
What I was trying to say in my first post was BS5266 does not say key switches are mandatory.
And an MCB is not designed as a Test switch and thus should not be used as such. The ACOP for Emergency Lighting and the NICEIC Guidance notes all recommend the use of key switches or similar for the periodic testing of such circuits.
Recommendations from private organisations do not constitute mandatory regulations IMHO.
Key switches are good practice in most cases but it depends entirely on the set up. This is how I wire them 9 times out of 10:
Outspoken just seen your tag line. I suggest you read the Bible again as on the beginning there was dark and God said let there be ligh. Light was on the First day not the 6th
I cannot agree because the Big bang, which clearly occurred even before the iron Age Sky demon, created Light in the Universe, so there was plenty of light going about, however here on earth we had no control until God gave us Light Switches. They should have arrived on the first day, but the wholesalers where bloody useless back then, even more so than today, so they arrived late!! :D
Reply to emergency lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That does help, it shows that the problem is almost certainly in the way it is connected and not a problem with the fittings.
davesparks
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
