Emergency lights | on ElectriciansForums
Discuss Emergency lights in the Australia area at ElectriciansForums.net
Dorset
If an internal emergency light is installed above a door that opens out of the building is there a requirement to put an emergency light outside also? If so can you give me the reference?
i cant see why. emergency lighting is to identify escape routes, and allowyou enough light to be able to escape. A light outside wouldnt allow any of this, unless the area outside the building is restricrted, and formspart of the escape route also?
Reply to Emergency lights in the Australia area at ElectriciansForums.net
Or a combined fitting in each row.
nicebutdim
N
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
