Emergency Power Systems / UPS | on ElectriciansForums
Discuss Emergency Power Systems / UPS in the UK Electrical Forum area at ElectriciansForums.net
B
BillyBigBalls
I am trying to find more information on emergency power systems in public buildings. Is there a definitive source of information out there that I am missing? A Guide, code of practice, regulations, etc.
how long does it need to run for? chances are a generator will be the way to go.
I would recommend a specialist to get involved because when you start adding changeover switches and multiple supplies there are a lot of regulations.
ups are good but they dont last very long and are expensive and need a lot of space
Depends how seamless you require it to be. Is it a case of the protected areas must run at all times so that if the power does drop the ups takes over until the generator comes in which may be 2 mins later to take the load off the ups which are more of a short term solution. Or if it doesn't really matter if it drops for 2 mins and then the genny takes over. It'll depend on what the public building does.
Reply to Emergency Power Systems / UPS in the UK Electrical Forum area at ElectriciansForums.net
It's a talk talk connection in London if the IP can be believed. But the user flag which never lies shows their true country. It'll be a link...
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
