EMG Lighting cert | on ElectriciansForums
Discuss EMG Lighting cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
Richcar
On an Emergency lighting completion cert PAGE 1 under the heading BSI installation category, it asks for the following:
Type
Mode of operation
Facilities
Duration------- (I can do this bit)
What do I fill the boxes with :confused:
or is that mode? it's late. the beer has kicked in, eyes are tired, my mode in the next 10 minutes is kip.
Cheers guys for the response.
The answers I found eventually were as follows:
TYPE
self contained or central supply
MODE OF OPERATION
non maintained
maintained
combined maintained
combined non maintained
compound maintained
compound non maintained
satellite
FACILITIES
including test device
including remote test mode
including inhibiting mode
high risk task area lighting
Duration self explanatory really
Hope this might help another fellow tradesman
Heres the full list of El categories.
7.10 Categories of operation of emergency lighting systems
Categories of operation are specified in BS EN 50172:2004/BS 5266-8:2004, 5.6.
In this standard, emergency lighting systems are classified according to the following parameters, as given for luminaires in BS EN 60598-2-22:1999, Annex B:
a) Type:
X self-contained;
Y central supply;
b) Mode of operation:
0 non-maintained;
1 maintained;
2 combined non-maintained;
3 combined maintained;
4 compound non-maintained;
5 compound maintained;
6 satellite;
c) Facilities:
A including test device;
B including remote rest mode;
C including inhibiting mode;
D high risk task area luminaire;
d) Duration of emergency mode (in minutes) for a self-contained system:
10 to indicate 10 min duration;
60.............1 h duration;
120............2 h duration;
180............3 h duration.
Previously, emergency lighting systems were categorized by the prefix “M” for maintained and “NM” for non-maintained systems, followed by an “/” and the number of hours duration claimed for the installation, e.g. for self-contained systems:
M/1 was a maintained 1 h duration system; this is now [X][1][****][60]
NM/3 was a non-maintained 3 h duration system; this is now [X][0][****][180]
NOTE **** in the third box stands for the facilities [see item c)], details of which are added, as applicable, at the time of installation.
Reply to EMG Lighting cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
