EMMA consumer unit | on ElectriciansForums
Discuss EMMA consumer unit in the Australia area at ElectriciansForums.net
sam80
Can any one help me with what mcb's fit in a Emma board other than the Emma ones. Thanks.
I think EMMA were the same as Contactum, but Contactum have had a redesign in the last few years so you'd have to investigate whether the MCBs fit. Take one off the board into a wholesaler and compare.
Reply to EMMA consumer unit in the Australia area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
The trunking on show there is only big enough for maybe 2 cables…. And a relatively new addition. Having an EICR done would give you an idea of...
