End of line.. | on ElectriciansForums
Discuss End of line.. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
tigerpaul
Tadley
I've been testing on a commercial installation where all lights are sat in the ceiling grid and then flexed back to a central LCM. One LCM per room/area.
The LCM is then flexed into a klix plug+socket on a conduit.
Now we're being asked to test r1+r2 and Zs at the klix socket. (as it's easier and were up against it at the minute) But this is not taking into account the additional resistance of the flexes away to the light fittings. So it's not truly end of line is it?
Surely I am right when I say the measurements should be taken at the last fitting? I know i am right really, I just come to get feedback and other opinions from you guys..
You only need to test up to the LCM then.
These set ups, usually have all the leads the same length.
Disconnect one of the leads to an LCM, then use that as a test lead.
Plug it into the last point on each circuit, and test at the end of the lead.
When you've finished all the circuits, re-connect the lead.
The LCM is fused, that fuse protects the circuit down stream from it.
Your Zs are required to confirm that the Circuit Protective Device will operate in the specified times.
It's the same as with an FCU.
We only test to LCM , when you test a ring do you test the appliances plugged into it?
No because the devices plugged into it are always going to be random. But the lights in the ceiling are going to stay. And if anyone gets a belt, then most likely that is where it will be.
I get the point though about the fuse in the LCM protecting everything downstream. That hadn't occured to me as I'd forgotten it was there.
Reply to End of line.. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
No live and neutral at the wall. But that would be the switch live right?
