O
oldtimer
All
I have just changed the CU in my brother inlaws new house he has a 2 bedroom end terrace and there is 4 in the block he has a 3 phase swa cable supply to his house and this supplies all 4 houses in the block so when he gets his extention done next year and then gets the house tested for building control (Scotland) How do you test the main ELI when there is 3 other houses connected to the main cable via 3 16mm earth cable on an earth block. Plus how if one of the other houses were to be tested how would you get around the various other paths to earth ? If you see what I mean.
