End to end resistances | on ElectriciansForums
Discuss End to end resistances in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
stidge
Nottingham
Testing a ring main today R1=.38 RN=.38 R2=.38 As you can see the same low reading on the cpcs.I have checked these and am sure they are only 1.5mm(L,N 2.5mm) Whats occuring?Has anyone else come across this.Thanks in anticipation:confused:
Hi stidge, had a ring main a few weeks ago where the end to end on the CPC was lower than that of line & neutral! Never got to the bottom of that one either.
I know what it should be old dog but what suggestions have you for the reading im getting.ta
Thanks dazza
Thanks dazza
last time i got reading near that the t&e was in conduit its hard to say without
knowing more about the set up as mark pointed out some sort of parallel path
hi guys just a thought ive had this problem a few times and its been because at each socket the cpcs have been twisted together and sleeved together you wouldn't belive how much difference it makes?
AJ
Reply to End to end resistances in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It was a one time ÂŁ19.99 fee. I'll be reaching out to them though to get that back. It was the only online extensive bank of questions that I...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
