Ener j WiFi receiver and switch | on ElectriciansForums
Discuss Ener j WiFi receiver and switch in the UK Electrical Forum area at ElectriciansForums.net
South East Kent
Morning,
Having a little trouble with the above receiver and I am sure it is something really simple.
Got an exsisiting 1g switch wired to the switch (live feed and switch line). I wanted to connect the WiFi receiver and switch to work like a two way. The receiver has the terminals live in/live out, neutral in /neutral out, s1 and s2.
If I wire it by bypassing switch it works fine . The wiring diagram says I can use the s1 and s2 to wire in the existing switch it it does not work .
If anyone has used these before or highlight the simple thing I missing it would be great
Reply to Ener j WiFi receiver and switch in the UK Electrical Forum area at ElectriciansForums.net
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
