Hi all
first job with enphase system all registered ok see real time data put in scoket of pv board to envoy so
on same circuit board.
put in a addon NHP2010 with HP200, NHP2010 plugged in & envoy input to this unit, HP200 at router
end plugged in, put in extra socket from consumer unit on same RCD & breaker as the router is plugged into
on domestic down stairs ring circuit, no comms over line!.
any help would be apprecaited?
work around i used 10meter patch lead & plugged envoy into router got IP address & real time data
built array issued all micro inverter serial numbers all ok just when i try wirless comms.
can you use usb on envoy?
