Well, got the system installed. It was a bit of a faff as the panels were spaced around 2 velux windows so I had to cut the supplied enphase cable and splice in an AC extension, connected in IP rated boxes attached to the frames, a proper pain, especially as the Enphase AC cable is reall really difficult to strip! Would avoid using the enphase on a layout like this agin probably, better for a continuous block of panels.
I'm not a computer techie so was dreading the setting up but it was actually reasonably straightforward. I made a couple of phone calls to enphase who were really helpful and didn't laugh at my stupiditiy!
I'm quite interested with the way the system is now performing. This is a south facing roof, with no real shade characteristics, but there are still quite significant differences in individual panel outputs. I like the onliine interface and initial impressions are that there should be some good harvesting gains even on an unshaded roof compared to using a standard inverter, time will tell!
