Hello,
I have a Potterton Neateheat 10/16 with an EP2000 programmer, which has been been working fine and very faithful for the past 26 years.
I recently had the consumer unit changed from the old fuse wire to a Wylex High Integrity unit. When the fused spur is switched on for the boiler
the RCD which protects the MCB for the upstairs ring (of which the CH fused spur is connected) trips.
Fault finding so far,
Purchased a new EP2002 programmer, same back plate, (although I have fitted the new one), still trips.
To eliminate the component parts of the system, ie pump, 3 way valve, stat & boiler I removed the front panel of programmer and linked
Live - HW boiler starts no trip, then linked Live - CH boiler starts no trip.
I then disconnected the feed to the fused spur and ran a seperate cable to it from the unprotected side of the main 100a trip, (yes I know, dodgy
but I had switched of all RCBO's & RCD to the rest of the house, only this cable was live as I wanted to simulate my old unprotected fuse box),
refitted the front of the programmer and the programmer works, led's light CH & HW work fine.
Contacted Potterton support ..... "Hmmmm never heard of that mate, can't help you!"
Any ideas please, Jimbo
