Epcs solar savings number | on ElectriciansForums
Discuss Epcs solar savings number in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
solarhappy
I have noticed that the EPC figures for a 2.5kw system for the solar savings is extremely higher than any other method for working out the savings.
Anyone else noticed this and surely this is extremely misleading?
RECC figure is nearly half of this for SAVINGS alone.
regards
EPC - you mean the ÂŁ837 :) over 3 years, Yep nicely generous isn't it! Seems to think that you'll self use 100% of your generation.
In practice we take everything on an EPC with a big pinch of salt, we also do renewable heating and the figures for space heating and DHW are also highly questionable.
See the other comments about battery storage :)
on the flip side the costs given were also about double what they should be last time I looked.
Reply to Epcs solar savings number in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
Hi KungFu Turkey Leg and Mainline Thanks for the link Mainline I will see if they are any help. KungFuTurkeyLeg, as far as I can see the mppt...
