Do any of you guys test for erroneous connections when you are doing your IR tests?
Discuss Erroneous connections in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
long time since i checked for a erroneous zone, still never found one according to the wife
up to a point. if there was a short, you'd read 230v, but if insulationn breakdown, your tester might not show a reading.Hi Sintra, wouldn't safe isolation with an approved voltage tester be another way of doing the same thing?
Or do i go the to the back of the class with Ezzze
Reply to Erroneous connections in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
