Guys, was doing an earth fault loop test earlier with a Megger multifunction tester. Got an error message after a few beeps. Have had problems in the past with the same message and found to be a loose earth somewhere on the circuit, any thoughts on what else might be causing it. Circuit concerned is a lighting circuit, emergency lights and pendants combined, about 10 lights in all. Connections made by a.n.other, can go back and check them all if there's no other way
Cheers
Cheers
