Esse cooker and a neutraliser
L
Lofty
Hi All,
I've done 'S' plan and 'Y' plans etc before but on this build we have the following....
'Esse' wood burning cooker / boiler.
Neutraliser.
Cyl stat
Pipe stat (at cooker )
Pump
1 x 2 Port valve.
NOTE:- NO room stat, no programmer.
The boiler will only be used for hot water and is complimented with a soloar panel system ( this will be installed by specialist company).
Has anyone got a wiring diagram for the above by any chance ?. The Esse web site is no help at all.
Cheers,
Lofty.
