eStat 761 Underfloor Heating controller fault | on ElectriciansForums
Discuss eStat 761 Underfloor Heating controller fault in the UK Electrical Forum area at ElectriciansForums.net
Soulsurfer
Channel Islands
Hey all, Looked at an elements eStat 761 controller today as during loads of other jobs, customer said not been working for some time since buying the house. Checked RCD fcu and fuse, all good removed controller / stat and had 244V and yet nothing on the display at all, removed floor sensor cable and tested at approx 18 degrees in room, got 14 kOhm and 127 Ohms between L and N feed into controller. Can't find as yet any other websites listing any testing resistances etc.. for the system and just wondered if any of you knowledgeable crew on here had any ideas before I get a replacement make from wholesalers in case it's not the controller. Date on pub of unit was Jan '08 so may well be broken by now. Can't see it being a mat that has been sat under the tiles, but never really dealt with any of them. Thanks.
Thanks men, that's sound. Saw online only 760 or 763 so that confirmed my thought that the same functions plus extras on the 763 was the new version. There was another make in stock at the wholesaler but not sure if worth using it as a replacement one. Heat something or other. A bit cheaper too, prob all the same really I suppose.
There is usually a handbook for the underfloor heating where some values are entered for different stages of the installation, if you can get your hands on that it will put your mind at ease that it's just the controller. Fingers crossed for your customer that it is!!
Reply to eStat 761 Underfloor Heating controller fault in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
