Discuss Estimated age for this sort of cabling? in the UK Electrical Forum area at ElectriciansForums.net
When pvc lighting t&e came in it was available with or without cpc, the cheap jack firms usually used the latter.i think VIR was in use until the 60s....then was replaced with the early PVC stranded ...which also lacked an integral CPC on lighting cable......
we still come across this PVC non CPCd stuff quite a bit in the renteds we service....When pvc lighting t&e came in it was available with or without cpc, the cheap jack firms usually used the latter.
Just took a look at my brother in laws flat. 1950's build, all metal conduit in concrete and not a cpc in sight. Ex council property so the maintenance was done on the cheap, 10mm (or imperial equivalent) MI tails, luckily someone in the past has put a 10mm main earth in.we still come across this PVC non CPCd stuff quite a bit in the renteds we service....
eye...they dont like letting go do they..BS3036s....not unless their really pushed...lol...Just took a look at my brother in laws flat. 1950's build, all metal conduit in concrete and not a cpc in sight. Ex council property so the maintenance was done on the cheap, 10mm (or imperial equivalent) MI tails, luckily someone in the past has put a 10mm main earth in.
He wanted me the fit a new CU, until most of the IR tests came back low, something to be said for bs3036, some still had the original pre-shaped filament in unlike his lighting circuit protected by a paperclip... :earmuffs:
For the very nice metal spotlight bars he fitted that are drilled into the concrete slab roof and not bonded in any shape or form to the conduit, apparently his screws weren't long enough to reach the conduit box. He now has some flyleads to bond the fittings to the conduit.So why would you need a CPC in Metal Conduit then??
The last inspection date for the installation was June 2000 when it was still council run, they may have done the work as a matter of course or the bonding could be failing on the installation. As I said, I only had a look, no testing was done. I agree that the MICC would be more than ample for the job as long as the connections are sound.Why would you need a 10mm main earth put in, when a 10mm MICC is being used as the main supply to the installation?? The copper sheath's CSA i would think, is neigh on 10mm...
Reply to Estimated age for this sort of cabling? in the UK Electrical Forum area at ElectriciansForums.net
