Estimating software | on ElectriciansForums
Discuss Estimating software in the Business Related area at ElectriciansForums.net
J
jonboy1
For many years now i have undertaken the labourious task of estimating time and materials without the help of any software. Due to the fact that i am beginning to get bigger and bigger tenders this is eating up a lot of time. Can anyone advise me of some software that has been tried and tested which would help reduce the time i am spending estimating.
Thats the one I use along with spons estimating costs guide to electrical works ISBN 9780415469043 combine the two and you can give accurate and consistent quotes in minutes.
Chris
Chris
electrika estimating software i to have used this but i cant find any of my whole salers that know how to enter there discounts and i haven got a clue
as for time i assume you enter a time per unit and the estimations are done for you but again i cant work out how to do these either
am i just thick or is it a job for rocket engineers
No it's simple enough to use. I prefer to use the times from the Luckins guide however. It annoys me that spons combine the install times for back boxes and wiring accessories. A question for those that do use it. What times do you allow for chasing, lifting boards, drilling holes? The times given in both Luckins and spons seem to be very very high.
Must admit I prefer my linked spreadsheets to electrika, that said it's nice to be able to save estimates and be totally automated.
spons give 6.70 per metre for cable chasing into brick or block wall 50mm wide as for entering times if you have an item with a catalogue number click on the stopwatch at the top of the screen and enter the information you require this will only work with cat numbers. Those that give you discount have to email a file to you.
Chris
6.70 what, minutes? If so you must have the very latest edition, I'm sure mine states 90mins for block and even longer for brick.
Sorry for my ignorance
Reply to Estimating software in the Business Related area at ElectriciansForums.net
I went with a partner. We're able to support each other and take time off knowing the other is at the helm. We split all profit 50/50 whether we...
I'd recommend getting a website up and running ASAP. And sign up to google business thingy so your website ends up in Google maps etc. Fill it...
