J
john waddell
hi all i am helping a friend out he has 2 big flood lights which are rated at 230 to 240 volt 50hz. they have a two pin european plug on them which states 16 amp. whats the easiest way to run them in the uk?
Discuss European Lights With 16 Amp Plug in the UK Electrical Forum area at ElectriciansForums.net
Are they for outdoor or indoor use. Do the existing two pin plugs have an earthing contact on the side of them.hi all i am helping a friend out he has 2 big flood lights which are rated at 230 to 240 volt 50hz. they have a two pin european plug on them which states 16 amp. whats the easiest way to run them in the uk?
Reply to European Lights With 16 Amp Plug in the UK Electrical Forum area at ElectriciansForums.net
