EV Charge Point with Usage Data for Billing Employer | on ElectriciansForums
Discuss EV Charge Point with Usage Data for Billing Employer in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Risteard
Supporter
V.Nearly Esteemed
Derry, Ireland
A question perhaps for @Gavin John Hyde or others:
I have a potential customer who is looking for an EV charge point installed at his property to charge a company vehicle.
He needs to be able to generate usage reports for his employer to be able to claim back the cost of charging the EV.
Any thoughts on the best solution for this?
He could install a private meter on the circuit to the EV charger.
How will he separate out his private from the business charges though?
I had thought of that (though it would have to be a MID meter presumably), but he seemed to be interested in some sort of automatic report from an app or whatever that he could e-mail through. The likes of Zappi will obviously display consumption when in use, but not sure whether reports over a certain period of time can be done with it.
I have usually fitted meters on the ev circuit and left it to customer to report as needed. some its all work. others record reading before charging and then record after. it can be backed up with data in the apps.
I have for one customer fitted a charger with payment options, customer used company card to pay for work car and rfid with free use for wifes ev. its worked really well as the two rfid chips have different settings. 1 work 1 personal.
company really pleased with this set up as they simply need the per kwh cost from employee and add it into the software.
will soon be fitting a few more for people at same company
Don't most smart charge points include historical usage and cost data in the dashboard or app? Would this not be sufficient?
Reply to EV Charge Point with Usage Data for Billing Employer in the Electric Vehicles Advice Forum area at ElectriciansForums.net
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
It is quite a simple process, if you believe a Hazard exists then an Analysis should be done, if at the conclusion of this Analysis this...
12K
Aside from 5 years, what is the time limit between inspection date and EICR being generated?
