W
wottie
ANYONE RECOMMEND A GOOD INSULATION, LOOP TESTER, MULTIMETER FOR USE IN ZONE 1 HAZARDOUS AREA,S:happy:
Discuss Ex TEST KIT in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yep understand the need of I.S. Test kit but can only find the Fluke 87v ex but this is a multimeter only, What about Insulation tests? i assume this is done on a plant shut down with gas risks removed and monitored at all time.
if you pm me i'll tell you of a company that may be able to help.
Not sure if i can post the name on here.
Reply to Ex TEST KIT in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
