Existing external lighting circuit. | on ElectriciansForums
Discuss Existing external lighting circuit. in the Australia area at ElectriciansForums.net
sparks72
I want to add a light fitting to an existing circuit (installed around 5 years ago).
has one fitting on the circuit at present with an switch in the garage on a 6 amp MCB, tested out fine,
do I have to put an RCBO on the circuitif I add on to it ?
Thanks in advance :confused:
I would say that you will need to put in an RCBO or an RCD just for the light that you have installed.
My rationale for this is that if you were just replacing the existing light then you would not need to do anything...however, because you are altering/ammending the existing circuit and thus altering the characteristics, then you need to make sure that these changes adhere to the current Part P regulations, which means BS7671 or an equivalent.
Yooj
Special location jumps out at me !
I believe RCD protection would be specifically required if the light is in a special location or the wiring to it is concealed in a wall to a depth of 50mm or less blah blah blah.
As you mention a garage the circuit should be RCD protected anyway. If it isn't, you cannot add to the circuit unless you protect the entire circuit, as you would be adding to a potentially dangerous circuit.
You need to check the bonding and earthing arrangements are up to scratch before you can even unpack your tools.
A garage is not classed as a special location. Sockets within it that maybe used to supply portable equipment for use outdoors must be RCD protected. Lights, unless they have exposed outdoor connections don't need to be RCD protected.
Reply to Existing external lighting circuit. in the Australia area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
