Hi
I've got three lights in my hallway that I'm changing to a LED light fitting - they are all controlled by two separate switches. I've done two, but I'm stuck on the third one. The first light had one of each earth, L & N, and the second light had two of each (which I've squeezed in the connector block) but as you can see the last one, there's a lot more going on! is it a fairly easy job or do I need to call someone in for it?
Cheers!
Cheers!
