Exparience flat rewire | on ElectriciansForums
Discuss Exparience flat rewire in the Australia area at ElectriciansForums.net
P
Peter Woodford
A friend has just got a flat and asked if I can do a rewire. The thing is it's on the 12th floor and all walls are concrete and the only way I can see doing it is all in mini truncking any throughts
If most of the accessories are going in the same locations, it is possible to use the existing buried conduits, providing they are adequately earthed.
Other than that, its out with the chaser or of course, surface.
You will probably find the ceilings are concrete also.
how old is the property? sounds like you need to get a few fitings of and have a rummage around. If it is an older property there will be existing conduits in he walls that should be accessible. how deep is the plaster?
I have just done a rewire in a flat i had to chase all the wall out and run all cables with in 6" of the ceiling. but luckily the plaster was soft. i could not go surface but it would have been easier. I put all circuits on rcbos.
Hi mac, can you use singles in houses? not been in it long to know??
Thanks Justin:confused:
if its concrete and conduit and boxes, its more than definate that it is already wired in singles.
there is no problem using singles again, as long as the conduit is in good condition.
be aware the box lid screws are probably 2BA size not this new fangled metric 4mm stuff
and the conduit will probably be imperial 3/4" (slightly smaller than 20mm). so keep the screws and bushes etc. cos you may find it hard to get replacements
[ElectriciansForums.net] Exparience flat rewire
Place is about 30 years old and someone before has taken out lights and conduit in walls all sockets throughout flat is in mini trunking.Also main fuse is not in flat take it it will be in the main switch room
Reply to Exparience flat rewire in the Australia area at ElectriciansForums.net
M
What is causing water hammer in my flat? Hello I wonder can anyone shed any light on what is becoming an annoying problem? I had a new stopcock...
Mr Gwent
M
It won't be notifiable though as its not a new circuit, if you change the the tails from 16mm to 25mm is that notifiable? No, if you add an...
