export metering | on ElectriciansForums
Discuss export metering in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
solgen
Hi,
I know this topic has been discussed before, but ...
Is it a requirement to install an export meter for systems over 30kW? The building to which the system is attached will consume at least 90% of the energy so it may not be worth the extra cost of export metering compared to a small 10% revenue for exporting.
Thank you
Hi, so for clarity, you do not have to install an export meter over 30kW? So if a customer was to use all of his energy generated it wouldn't be worth having one?
i.e. from memory you need to export in the order of 15,000kWh to just break even ......
Reply to export metering in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Regulations here require that live parts can not be accessed without the use of a tool, but in this instance the service block will most likely...
nicebutdim
N
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
